Non detergent oil
Status
Not open for further replies.
ford3
there have been a lot of post on whether to use non detergent or detergent oil, the easiest way to answer that question is to take the time and take apart an engine that has been run on non dertergent oil and look at the god awful amount of sludge built up in the pan and valve chamber, then you deceid if you want to follow the manual thats over 80 yrs old on what kind of oil to use, then you make the choice
I've got an original '29 Chevy that I burn non-deterent oil in. I will continue to use the non-deter. oil until (if ever) I drop the pan. I'm sure it is half full with sludge. On
my two "A's", one with a filter and one without, I use detergent oil.
Bob-A
Status
