Do you really mean 'steel' drums? I've seen many posts on this, over on ahooga, and I believe the consensus is that steel drums aren't so hot, as in, don't work so good, and make noise ??? Might check with the 'A' guru's... ???
Also, my experience with 'modern' lining has not been too good. On my V8's, I've got 'modern' lining, but not the 'ordinary' stuff from the parts counter. I had to have a 'custom-installed' soft (very soft) lining installed on my shoes, and this has worked great. Also, note that Pete's comment about woven lining is a good one. I put the original woven on a 34, and have had good results.
The modern lining that I have seen, is way too hard for the early cars. Case in point, on my 47, the modern, HARD lining, made the brakes downright dangerous. JMO
