noise in drive shaft
benp
How does one rebuild a 1948 Tudor drive shaft. Have a grinding noise in the center of the shaft. Speedway has a conversion kit to install a drive shaft but I am not sure this is the way to go. Any help appreciated.
Contact skip@forerus.com He makes a replacement center bearing. Ask
for his removal and installation instructions. G.M.
Should have a grease fitting there. Bunch of threads here on this work including Old Henry's personal experience.
@G.M. Thank you so Much this is a Huge prize link. Skip also does coils and water pump, and center support bearings thanks.
