CP
ok, i had skip convert a coil to 12 volts. worked but spark was week. put on another coil and worked fine. so i sent the coil back to skip and he of coarse fixed it at no cost. he said i burnt it up and must have left the ignition on. i only had the ignition on during first startup, but...whatever. my new coil worked. anyway, i got the "rebuilt" coil from skip today and fired it up. started up no problem and ran for 10 seconds since i had the gas off.
anyway.....now i have no spark again. its very "week". it does spark, but barely. what the heck is going on?
i have a 10 ga. wire direct from the battery to the resistor. one wire from the resistor to the "batt" terminal of the rebuilt 12v coil (48 type). the other terminal goes to the distrib. pretty simple.
i took my coil off my running engine and dont have strong spark either.
"week" spark, what is it?
no cut wires...engine on stand.
resistance of wire is .2 ohms
resistor (i tried two) one is .6 ohms and one is 1.5 ohms
it ran with the 1.5 on for like i said 10 seconds and sounded great.
changed from the ,6 because i figured maybe that is why my coil burnt up.
however, not geting spark from a coil that i know is good is what is getting the best of me.
i have new wires and bought another set of wires....tried both. week spark.
help? cp
help? cp
