No spark help needed
Russell in Tulsa
I am away from home, my tablet won't let me search but I am able to post for some reason. Would one of you gents post a link I can use to troubleshoot my no start situation please? No spark at coil wire to ground when cranked. Thanks guys.
Check to make sure one side of the coil is hot (battery), from the other side it goes to the pop out switch then to the points and to ground when the points close.
Place a piece of paper between the points, then when you place a "quick" short across them and the pop out switch is in the "on" position you should get spark. If nothing then try quickly applying and removing a short on the "point or switch" side of the coil you should get a spark. If you get a spark by applying a quick ground to the point side of the coil, and not when you apply a quick short across the points, you have a bad switch, or a broken wire between the switch and coil, the switch and distributor, or a bad jumper wire in the distributor. This is all assuming you have an original wired car. Take it one piece at a time and locate the problem.
Thanks for the reply. Away from home, dark thirty here and minimal tools. No test light etc. Will get ride into town tomorrow to get necessary tools. Thanks a lot.
Mike, thanks for the help. I checked with a multimeter and found all was good. Rechecked point gap and was way off, regapped, lubed cam, added fresh gas and it started on the second revolution. I then drove to the filling station and every right hand turn my horn would blare out until I straightened out the steering wheel! I found the bail wire on the switch was ready to pop off. Got that fixed and am now one happy camper.
Thanks again for the flow chart, it really helped...Russell.
