Tom Endy
If you have a spark coming out of the secondary wire from the coil and the rotor is turning, I would suspect either the rotor or the cap. They can both develop a hidden crack that when a spark shows up it goes straight to ground. I would substitute another rotor and cap and see what happens.
A friend has a rotor he keeps for show and tell. It looks perfectly functional. You can check it with an ohm meter and it has continuity. Put it in a distributor and it will not work. It apparently has a hair line crack that is not visible from the center connection through to where it sits on the distributor shaft.
Tom Endy
Tom Endy
