Jeff/Illinois
Went out to start Roadster and she no go. Getting fuel won't pop off cranks likes there's no tomorrow SO
Checked the spark at the points and there is none. Point gap dead on .020" where I always run. Open and close properly points not closed up . Took my test light and started hunting. I have power across both terminal box connections (ammeter OK?) and both posts on the coil. Thought maybe condensor so I swapped that out and still nothing. Changed the ignition cable to the dissy w/ a new one, still no go. Checked the terminals at the ignition switch ( have one of the cheapo specials not a pop out) and my test light lites up when I flip the switch to 'on' from off, when I put the hot lead on the ignition terminal that feeds the cable to the dist. and then ground the other lead, so I think the switch is OK???
Got me kinda stumped and it's too hot and humid out, so I'm hiding in here drinking a Dr. Pepper
will attack it again tonite.
Any hints would be appreciated I do have another ignition switch I could try but since I got the test light to lite up by turning the switch 'on' I can't see that that is what it is????
Oh yeah have a Buss fuze wired into the starting circuit at the starter switch, fuze is good tried another one still nothing------------
