Tom Wesenberg
If you can't get 6 volts to the OPEN points contact with the key ON, then you might have the cable screwed into the housing too far. It only should be screwed in a couple turns, or three at the most.
I am frustrated on this one. With switch off, I have voltage from starter to both sides of coil. Ampmeter discharges when I try the horn. Took distributor plates (top and bottom) out to look for shorts and didn't see any issues. Replaced the wire from switch to distributor, thinking it might of been shorted out inside the cable, still no spark at the points.
What am I missing?? Thanks.
