I agree , I always clean and lightly sand new points , If nothing else , sanding will remove any glaze on the contacts . As for the condenser , If you are using the original style A&L condenser that the better model A vendors sell , its not likely that the condenser will be the problem . I have often called the so called modern points setup a make shift rig . The V8 points are no advantage at all and are difficult to adjust . I always eventually had problems with them . The wireless lower plate that is often used with the V8 points can easily short against the housing . Its your choice but I would recommend switching back to the original points set up. I had lots of trouble with the low cost ignition switch. I had to change to the slightly over fifty dollar switch for dependability . When you set the timing , Set it like Tom Wesenburgs pic. Any rotational backlash in the distributor shaft should be in the counter clockwise direction where it will have no retarding effect on the timing when the cam screw is tightened . Any clockwise back lash in the distributor shaft after the screw is tightened will cause the timing to be retarded . The reason clockwise backlash causes retarded timing is the engine will have to turn to catch up the backlash .
