No room for more trucks
Here's a picture of the guy (Rollie Free) in the picture above getting started off. Wearing nothing but a bathing suit he set a record of 150 mph in 1948 on the salt flats. CRAZY. In comparison a spread out free falling skydiver typically maxes out at around 120 mph - I did that once and it felt like my cheeks were going to fly off!!
592577
Looks like a mighty Vincent. Very fast, but they prefer to only drive in a straight line, or so the story goes.
592577
Are those two guys in the background looking towards area 51? They do look rather 'otherworldly'
Gary, when you get the Hatzuki to Bonneville, going with "Lumberjack" flannel material for your speedo would really represent your area of the country best. Suspenders go well with flannel and should help to prevent it from blowing off at the high speed you will most likely attain.
Scotty, Please! Lord help us to 'unsee' Anybody in a flannel speedo with suspenders, especially Me!
On the original subject I built a receiver hitch mounted cycle carrier this afternoon from 2"sq with 1/4" wall and 1 1/2 sq with 3/16" wall. Two 6' rails of 1 1/2"with 5 1/2" between for the tires, as the rear tire measures at 5 3/8" wide. This is primarily for the '59 F350 with the 9' pickup box and a very stout 6x6 H beam for a rear bumper. Soon to build another crane with another WW2 Navy bomb hoist I picked uo last year. I will have the option of loading the Hatzuki into the box or onto the new carrier. But for tomorrow I'll load it on by backing under my 5 ton Beebe Bros hand crank winch in the shop. I'll get some pics tomorrow. I hope to take it to some events next summer, and from trial runs, Let's just say it's one of those vehicles that might be more fun to look at than to actually ride (at least on the mainland).
The search for better hill climbing ability has reached fever pitch. This morning after doing all the comet clutch tweaks that youtube had to offer along with a very expensive custom made rear sprocket, I decided to tear a page from some early lawn mowers and other vintage power equipment and ad an auxillary belt tensioner. This tensioner keeps the v belt deep in the front groove and inhibits the belt's ability to climb to a 'higher gear', all the while providing a much larger area of 'wrap' for less belt slip. As my rpms dropped on an incline, the centrifugal weights would relax their grip on the belt, adding to my woes. The tensioner is just for the hill climb and by pulling the lever back for normal road use, the CVT action of this comet type clutch is resumed. I have always tried to keep these videos on the short side, but this won't surprise any of you that it ran 13 minutes. I just hope someone searching for this info will come across this in the future. You might wanna pop some corn... :)
Thanks guys. Been PM ing with Al Hook who has experience with these CVT 'clutches'. He suggested the idler on the slack side {bottom' of belt was more customary. I told him I awoke this morning, laying in bed for an hour thinking about the same thing. My thought was turning an engine over by hand, using the fan blade for instance when setting points or valve adjustment. The belt gets excellent traction if you press on the loose side (ahead of the diving force) Behind it does next to nothing and the belt slips. My idler worked great to use up the comet's required belt slack and keep the belt from rising up into a higher 'gear', but I do see further improvements in eliminating belt slippage if I put my tensioner below. Perhaps a common spring loaded automotive serpentine belt tensioner with a link to my tankside lever, which I hope takes my scrap-built frankenbike one step closer to my lifetime dream bike, a harley WLA 45 cu in Flathead. And has there ever been a flathead diesel engine?
Well, Al's suggestion of mounting the tensioner on the slack side finally got this thing running like a real 'store bought' motorcycle. The belt drive feels more like a roller chain. Pretty much like my fan blade analogy. And Skip, with tensioner on the top side of belt, the shift on the fly lever was easy as can be. Now with the tensioner way down low, I envision a bell crank or two and or something with heim joints ending up in my tankside shift lever. Gonna be a regular Dr Suess engineering exercise, but well worth it. Scenario at Bonneville. I start out in my granny low, but once rolling I pull back on my 'tank shift' and the full 8 hp transfers to the salt. The comet clutch, now free to take care of all the 3600 rpms available (until the factory governor kicks in) oh never mind . At least my speedo stays intact as I cross the line at a respectable 45 mph.
Since you have the one and only, that 45 MPH would be a record. Then you have a year of fiddlin to adjust some things and break your record. ;)
A year from now if I survive this madness..... Speaking of madness, I went down to the shop in my jammies at 5:30 this morning as I woke up with a great vision of tank shifter linkage. there are two well placed pivot points in the left downtube which were engine mount attachment points. Basically small tubing welded crossways through the down tube. I threaded them for 3/8-16 bolts. I may bolt a triangular plate into these holes and a pivot on the tail end of it to move the shifter aft. I continue to utilize old ford parts whenever I can. Today it's a V8 valve train 'top hat' that sits inverted into a valve spring (rotator type ?)I used as a spacer in a pivot. For my shifter, 20 years ago a friend brought me a really cool forged steel lever that is probably a bit too heavy, and need to get it cheery red for a few bends. I also have a big truck push button parking brake lever with a quadrant and pawl at the bottom and somewhere a crash box shift lever with the thumb trigger below the knob to lock it in once the belt is correctly tensioned. oh wait it's operated by the Left thumb!
Funny, I went to Bonneville Speed Week in 1978, Totally by accident. I was driving across country from Maine back to Washington and i had friends in Tulelake Ca (so far north their address was 'Stateline Rd'). They wanted me to take care of their animals for 2 weeks so I drove a southerly route. One morning I was having breakfast at some joint and I kept seeing trucks that were hauling some very cool stuff and so I asked 'what's up'. A few hours later I was at the starting line. No rules posted. Harley guys all in the bed of an old dodge pickup pulling an over-geared bike on a rope so when they dumped the clutch in first gear it stayed running. I can't find the picture but for a long time I had a snapshot of a gal leaning over twds a guy in a streamliner with the words 'Thermo King... world's fastest diesel' emblazoned on the fuselage. Was a great picture Mark. Almost as good as that one you took of me.
I also went to Bonneville once, in 1972. Mary and I had made a big 2 week loop of the west, seeing everything we could, starting with Glorietta, New Mexico where we attended a Baptist Convention. We then saw the North Rim of the Grand Canyon, travelling north to Utah, where we saw the salt flats and a little of speed week. I remember a diesel-powered streamliner that was trying to break a record, maybe the same one that you saw. We were driving my nearly new '71 C.... pickup, with a home-modified camper/topper, which we camped in. On the front of my pickup I had built and attached a motorcycle carrier to fit my '72 Yamaha DT-1 250cc enduro. It was a little of a challenge to load and unload, but I was 20-something and determined. Our travels included Coral Pink Sand Dune St Park, near Moab, Ut., which I enjoyed on my dirtbike. A fellow was there riding his 3-wheelers, tho and offered me a ride on a Honda 250X I believe, and it was awesome in the sand! The thinner tires of my dirt bike didn't get nearly the traction of the fat-tired 3 Wheeler. I'll never forget the difference, I was amazed. We then travelled north to Yellowstone and Cody Wyoming, before trekking home to Kentucky. We travelled about 5500 miles in those two weeks! Great Memories.
Al Hook
There is always this in the way of Bonneville diesel powered vehicles
Banks Sidewinder Dakota​
This is the truck that shattered existing speed records – and people’s perception of diesel performance. Cummins diesel-powered Project Sidewinder set five land-speed records and became the World’s Fastest Pickup Truck.
Surpassing Gale Banks’ personal goal of 210 mph, the Banks Sidewinder smashed the world 159.647-mph record with an average speed of 217.314 mph, making Sidewinder the World’s Fastest Diesel Pickup! Amazing Overall Top Speed: 222.139 mph!
Try getting a pickup truck, with the aerodynamics of a brick, to go 222 MPH with a diesel engine. Banks did, and kept it street drivable too.
Al amd Tim. I love these stories. Do you know that in the early 50's Cummins entered a diesel powered race car in the Indianapolis 500? I recall there was a strange glitch in the entry details about mileage or something that made them competitive. From what I recall they did really well. I remember this from a book called 'The Diesel odysey of Clessie Cummins'. Also I got my low range lock device finalized today actuated by a side mount tank shifter. Ended up with a shift lever from a siezed up 3 speed ****** from a late 70's land cruiser. I chose not to chop up and alter a shifter from a V8 era Ford!
