1929ModelAFord
New member
1929 Tudor. Recently did valve job with guides and springs. Replaced leaking water pump with leakless model. Rebuilt Zenith Carb. Engine idles but has no power. Compression is 60 in all four. Looks like number one and two are not firing. Changed cap, condenser, points, etc. Vacuum good. Installed new ignition switch. WOndering if valves need readjustment. Will be looking for exhaust blockage. Gas flow looks good. Is it possible rings are 'bad' even if I show 60? Looking for any suggestions. Thanks
