I have a 1941 ford car. The trunk is open, I am trying to remove the handle the nut is loose. It wont come out, have no key for it, and it appears to be locked. any ideaws onhow i can remove it and change the tumblers.
Thanks fir any help
Phil
If the keying for a’41 is the same as a ‘46, the code on the glovebox lock should be the same as the trunk lock. As I recall, you need the key to get the lock out of the handle.
