Cyclone Curt
New member
I'm working on "Casey" , my 1930 Pickup, who is straight from a 30 year slumber in an Iowa barn. To get Casey roadworthy again, I've been working on getting the lights operational. I've hit a challenge with getting the high beams working.
Cowl lights work at the 7 o'clock position of the steering wheel switch. . Off is at the 6 o'clock. Low beams at the 5 o'clock, but the switch won't rotate further to get to the next high beam position. The top housing of the light switch has stops that only allow a rotation of 90 degrees. See photo. Seems like it should rotate 120 degrees so the contact "bumps" can touch four spots (off + 3 brass) on the bakelite contact plate.
The cowl lights were an addition. Would there have originally been two styles of switch housings, like 3 positions for without cowl lights and 4 positions for with cowl lights? Catalogs only have one type. Appreciate any insights.
Thanks for all the valuable info provided on this sight. Really helpful.
