jerry shook
My 51 ford truck with the original flathead. There is no fire from switch to coil I have checked the switch all looks good. Any suggestion on what to check.
The power for the switch comes from a circuit breaker under the panel and they can go bad. VanPelt Sales has wiring diagrams that should help you. The ignition switch controls instruments and radio (if so equipped) on the accessory setting and ignition + instruments in the run position. Whether you can still see the colors or not depends on the condition or origin of the wiring connected there. Lights are all controlled from their own separate switches.
