No compression
egm
Drove 31 Tudor into barn, running fine, next day wouldn’t start, no compression all 4 cylinders. Pulled head everything looks ok, valves move,new valves , 100 miles on them. Can’t understand how I lost compression in all 4 cylinders overnight. Any ideas? Thank you.
You can pull the side cover but you already have the head off. You said that you could see the valves move. Why?
If the valves are moving then you should have compression. What led you to think of no compression in 24 hrs.?
Valves move up and down well distributor rod turns feel no slop feel tight to cam. Valves tight to seats. Not sure what to look for next. Head gasket looks as good as new.
Cam may have lost it's relation to the crankshaft - broken teeth on fiber gear. The procedure has been covered hundreds of times here. Good time to get familiar with the advanced search feature. Try it, you'll like it. Saves a lot of time. Then, if you don't understand, I'm here to help and others as well. The picture in your mind is basically what is the 4 stroke cycle. Got to picture it to understand it. Model As are simple but the 4 strokes and piston position concept is universal. The goal is not to get the car running, its get the understanding to know what to do with the basic test results.
what kind of tappets do you have and what did you set your valves at? make sure the timing marks are still in line
Even if you wrung the teeth off the timing gear you would have compression in at least one of the cylinders,there is no cam position where a valve on all four cylinders open..so that rules out a valve timing issue. Stuck valves can cause it but you would have to have at least two stuck or burnt valves.Engine was running fine on shutdown so that rules out burnt valves,sticking is possible..any other issue would require 4 events to occur..at once...with no prior indication of a problem..
If every tooth on the cam gear is in good condition and each valve has some lash and things are going round and round as they should, there should be compression. Have you added a wee bit of oil to each hole ?
As hard as the crank gear is to get off I would doubt that is the problem, but, at this point it might be worth checking. Something just isn't making sense.
Put finger over hole no response.
In your first post you said you removed the head. Is it on or off now? - which hole are you talking about? I am very confused as to what has been done and what state the engine is as far as being apart at this time. Can't get much compression with the head off.:)
John
