If you have clean, burr free surfaces and use RTV properly it will NEVER leak. I have two engines with thousands of miles on them. No fly-housing to block gasket, no pan gaskets, no valve cover gasket, no water neck gaskets. Just RTV. As drip free and clean as modern engines.
A gasket will compress over time and eventually leak. If you use a gasket in an area where you cannot get to it to ever re-torque, like the fly-housing to block, expect eventual seepage. If it is a high point show car use all the proper gaskets and live with it. If not take a clue from modern technology. They don't call it 'form-a-gasket' for nothing!
