30 Closed Cab PU
Berts can modify carbs for air balancing for use with air filters during their carb rebuild process if you ask.
Good afternoon...I use an air filter from K&N and a mount from Bratton's purchased about 2005 or 2006. I can take it off and blow it out and/or soak it clean. It seems to work well for me. I believe that Dave Renner can supply jets that have been adjusted for use with an air cleaner...Ernie in Arizona
Renner also modifies carb bodies so the are air balanced.
