30ccpickup
Thanks to everyone's help the hub came off. The key on the axel is another story. It does not want to budge.
1. Can I assume it is not a press fit and it should come off.
2. And/or can I leave it pressed in the slot on the axel and not worry about it or more then likely that’s part of the problem why the hub was stuck in the first place.
Any input helps. Thanks
Paul
Paul
