I am looking for a wiring diagram for a NewRex three pole ignition switch for a Model A Ford. This is an upgrade replacement for the standard Pop-Out switch. The Poles are labeled BAT, Coil, and Acc. There is no direct to Battery connection in the standard wiring of a Model A. This Switch Allows the Battery Terminal to connect to both the Coil and Acc positions when in the run position and Battery to the Acc position when in the Aux position.
The Pop-Out Switch connects to the Distributor through the shielded cable and to the AMP meter on the other terminal which feeds through the coil. If wiring the Nurex through the Coil to connect to the BAT terminal on the switch, will this in effect act as the direct Battery connection for the ACC terminals to work in both the Run and AUX positions? Help!
