Welcome to the Model A Hobby! And to the Ford Barn! You've come to the right place.
<snip>
so my questions for now are
1. Should the carb drip?????? are they easy to rebuild, they sure don't look like there is much???? is there some one out there that rebuilds these back to like new condition?
2. And what battery is the best to use, one that you can go down to the parts store and get??????
3. Are there any must have books, manuals etc out there that i need for maintenace, wiring diagrams, VR setup etc etc
1. The carbs are easy to rebuild. They should not drip gas when the engine is not running, but I turn the fuel off anyway when parked in the garage. Yes, there are several guys out there that rebuild them. I recommend you have the jets "flow tested" because the reproduction jets being sold are really bad about flowing too much fuel. I can help connect you with someone good. See email address below in my signature.
2. The car is 6 volts. The starter turns kind of slowly, compared to modern cars. So people that regularly deal with cars from the '60s and '70s think the battery is weak. It may just need to be placed on a charger overnight. And the cables cleaned, etc. You can have the battery load tested to check it.
If you really need a new battery, get a 6 volt Optima battery. It will also require a special adapter to hold it in the stock battery box. The Optimas take the vibration of a Model A quite well.
3. There are several books that I recommend to start with, and then you build your collection over time. Too many at one time is over load on your brain.
If the car does not come with one, get a reproduction copy of Ford's original "Instruction Book" for your year car. This is like the Owner's Manual for the car. Read it and follow their directions. They knew what they were talking about.
Get a copy of the book called "The Model A Mechanics Handbook - Vol. 1" by Les Andrews (the "red book"). This has all of the basic adjustment, remove, repair, replace procedures for the mechanical parts of the car.
Get a copy of the book "Model A Troubleshooting and Diagnostics" also by Les Andrews (the "blue book"). This is a good book to carry with you in the car, along with basic hand tools. You can read through it and begin to understand that the car is very simple to fix, if you are systematic in your diagnostics.
I can also give you a short list of spare parts I recommend you carry with you (under back seat, with tools and book). Email me.
If you've never been a member of The Model A Ford Club of America before, you are eligible for a free membership. Contact Jay McCord at
FreeMembership@mafca.com and he will take care of you.
I am MAFCA's Technical Director and I help new Model A owners out every day! Feel free to contact me, by email or Ford Barn Private Message.
