pooch
Gday from OZ.
Bought an original mostly unrestored june 28 tourer 2 weeks ago.
Has seats amateur recovered and a new roof decades ago is all.
My first A model.
It had an irregular miss and took days to find it.
It is either the points or condensor.
Have ordered an upper plate with modern points/condensor.
It is 12 volts pos earth with powerhouse genny and seems to be charging fine.
A little high in amps, so I will bring that down a bit.
The coil is a black ford script and an A inside an irregular marking.
How can I tell if this coil is 12 or 6 volt?
And, if it is 12 volt OR I have to get another one, what points and plug gap should I use with the modern points/condensor?
Would .020 and .035 be wrong for a modern system?
Am getting a new motometer as old one is dead, how high should an A temperature run on say a 25C day?
Does the motometer rise much with no thermostat?
How does one put a pic of car as avatar here?
here is car....
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=300457986796&ssPageName=STRK:MEWAX:IT
My first A model.
here is car....
