Chevmn56
I recieved the 31 Tudor deluxe today, i have been pouring over the car and this site and the internet trying to learn as much as i can. There are some questions that i cant find the answer to
1. I think the engine has been replaced (A1708745) a decoder i found on this site said that the motor was made June of 1929....does this mean the engine has been replaced?? or was it that common to have that many engines stock piled???
2. Carb needs gone through where can i find the type zenith, tilly and model number to get a rebuild kit...........or are there some better ideas out there.
3. I watched a YouTube video by a old guy on brake adjustment......is it really that in depth !!!!!??????? or is there a easier way....making a board cutting steps etc etc.
4. Also there is a silver cast box around the exhaust manifold that says "Auto-lite" its hollow and air is passed through it to the inside of the car. There is a door and a flow adjuster on the inside so you can shutoff or decrease air flow and direct it where you want. is this a correct period piece?
5.On the engine there is a aluminium crank cover (on the side) that says "Powered by Winfield" what is this piecei havent seen it on any other pics of A's engines?
