Newbie needs help
DaveK
I just got a 1930 sport coupe and the drivers side rear shock is bad. I pulled the shock and it is still full of oil but the arm moves back and forth with no resistance. Can anyone tell me what might be wrong with it and can it be fixed? It is a Houlidine shock
Thanks,
Dave
There is a valve inside the shock that is plugged by a lead plug. If the plug has fallen out or is missing, the shock won't have any resistance even with oil in it. There are other things but, this would be the first thing I would check.
Ok I'm taking shock apar. There are two pins that need to be punched out, one came out pretty easy the other is stuck. How much force can I use to get the pin out? I'm leary to hit it to hard and damage it.
Dave
