GRUMPYONE
We are talking about rear axles.
I have searched and found some of my answers. I have an a model chassie 30 model. Mechanical brakes, question is when i went to pull the drums off they were sagging down. They have been rubbing the lower portion of the backing plates. Where would be a good place to start with. Would it be the bearings, inner drum race, or axle housing where the bearing rides on. Is there a repair kit out for this.
Lets see if i know where im at.
The axle will have movement when drums off, cause the hub contains the bearing to keep it centered?
This would failure of bearing, drum, race, or housing would cause it to come off center and rub drum and shoes?
I know safety is first and am on tight budget. Not to tight to want to drive to get hurt. I will let it sit before that.
Thanks ahead of time for the help
