30 A Ripper
What is a "hot air pipe", where and what is it supposed to do? Mentioned in a post regarding "rough running".
Noticed no one uses a dwell meter or mentions vacuum gage. Why? Is there a vacuum port someplace?
Is it a hole or just depression that the timing pin drops into for static timing? Does the pin ID match the hole/depression closely or with some slop? Don't understand what putting a point on pin helps?
I bought the Les andrews books but haven't digested much yet. Kind of going with failing memory <G>.
