Canton_Model_A's
Greetings to all. Need to know if i can use heat from a torch to get the old studs out so I can use the new ones that look like studs but are bolts...
Dave
Dave
Just to be fair, there's no reason you can't also use conventional cap screws (what we also call "bolts") in that same application either in a pinch or if you don't care too much about maintaining original appearance. Not a bad idea to carry a couple in your spare parts box for when you have to change a pump at the side of the road and misplace one...Thanks marshall
