New use for A wishbone
mach0415
This past week, my family and I visited the NC Transportation Museum in Spencer, NC. While the focus is on rail transportation (good place to go for train fans), the automobile exhibit was pretty cool. Several of Henry's examples are there - Model R, both brass and steel T's, a 1931 Slant Window Murray TS, among Buick, Willys Knight, etc.
Here is a pic of a vintage 1937 blue oval racer with a cannibalized A yoke to tow it with.
Mark, I am not seeing the picture.
Since you mentioned a racer, are you "into" racing? My son & I used to run at Cleveland Co Speedway every once in awhile. (Don't run our class now) Several of our friends are regulars there in the 'crate late' class. Do you ever go there?
Several years ago I organized an overnight club tour from Asheville to the NC Transportation Museum. They were giving rides around the property on a vintage steam train the same weekend. There were lot's of vintage train engines and cars plus old automobiles and trucks. We spent about a half day exploring the nearby Civil War cemetary and old hardware and antique stores in nearby Salisbury. It was an interesting and fun weekend.
I have seen later V8 wishbones used to make steel saw horses. They make good ones.
I wouldn't use model A wishbones.
t cut up model A wishbones
Dont'n mean to hijack the thread.
On the topic of old Ford parts put to another use, I remember seeing the axle housings from a closed drive Ford rear used for jackstands. They cut off the outer end and cut somewhat of a "V" into it. Thinking back on how it looked, I don't think it was very safe the car would be quite high off the floor and the footprint was small.
I've seen lots of jack stands made from Ford closed drive axle housings. They could be made .in different lengths, depending on where the small end of the housing was cut off. They would then weld on a short length of channel iron. I still have people ask to buy some of my axle housings for that purpose. I allways refuse, I may need them later, especially if the outer bearing surface is still usable.
Tow bars from old Ford wishbones was a very lucrative business for us in the olden dayz(50's)...It took about 15 minutes to build one and we got $25 for it.
I thought those were the only jack stands in the world till I was about 21. BTW, the bearing surfaces are always repairable. I do them in my shop.
I survived a number of years working under cars supported by the Ford axle jackstands. The trick was to go around and rap each jackstand with a big hammer just above the floor in every direction. Usually you would see/hear the stand move a bit to sit flat on the floor. THEN you got on the creeper and slid under.
I agree. When I went to work at Stewart Chevrolet in 67, that was the only jack stands that they had, same at the GMC dealership. They were still a lot safer than some of the foreign stands that are on the market.
T model rear end housings make the best jack stands. The axle tube is not tapered and a piece of 2" steel tubing will fit right in. Drill a row of holes and use a bolt or late model valve for a pin and you have a nice adjustable stand. The foot print is 9.25" and is very stable on concrete.
