Synchro909
From what you say, I think only one cylinder is holding it. Have you tried rocking the car back and forth while in top gear? Also, make sure the clutch plate is not stuck to the flywheel. You can check that by peering through the inspection cover on the flywheel housing.
Once you have it free, and running, listen to it carefully. Very often, when an engine has been stuck for a while, the rings leave a groove in the bore and will catch on it every time they go past it. You may be able to feel it withthe crank handle or hear it with the motor running. If that has happened, a rebore and new pistons is in order.
Persistence is omnipotent!
