Here is a reply I made to the same inquiry mid last year. Since then I have now done 5000 miles on the Bill Stipe shocks and they are working fine.
"I fitted A Snyders "shock pack" about 3000 miles ago. The arms and dog-bone links were fine, but 2 of the M&S shock casings in this pack split along a deep groove cut into the outer threads . The cast iron was very thin in the bottom of this groove, which also had the internal thread adjacent to it - about .020 in some cases. It obviously gave way under the hydraulic pressure. It looked like the groove was for a packing, but there was none in any of them.
I had not altered the adjustment of the shocks when installing them. I also noticed other issues when I took the remaining two apart. They had lost oil, and had slack movement in them because of this . The oil is very heavy - about the same viscosity as Model A axle oil.
In all cases the O-ring in a groove in the shaft had been cut on original assembly and the cut-off bits of rubber were floating about inside. You can also see steel rag from the machining on the edge of the rotor, and some of this was broken off and loose in one shock.
Snyders were brilliant when I sent them the pics and explanation. I asked for Bill Stipe shocks to be sent (their "premium shock set") and they credited me the M&S shocks in full and sent the Stipe ones by air post - postage free! I did not ask for this - they offered.
Since I live in Auckland New Zealand this was quite a bonus.
The Stipe shocks are about twice the price, but they are beautifully made, 60/40 resistance like the originals (M&S are 50/50 bump/ rebound resistance due to a different construction), fully adjustable and replenishable with 30 weight synthetic hydraulic oil. The M&S ones have no oil in the "reservoir" which is a dummy, and they must be dismantled to top the oil up. Then re-sealing is hard to do on M&S . I brazed one body back together as a temporary fix and made it work again, but I believe it would soon lose oil again due to the stiff action caused by the valving and very thick oil, which must combine to cause very high instantaneous hydraulic pressures when large bumps are hit.
The M&S are adjustable too, but the lighter action the Stipe shocks are supplied with is not attainable on the M&S ones.
I have only done 100 miles on the Stipe ones, which I fitted last Friday, so can only comment the ride feels good and there may even be room for improvement when I decide what adjustments they need (if any).
The ride on the 50/50-action M&S shocks was OK too, until they burst or lost oil.
The shock arms and dogbones in the original pack were well made and work fine.
Stuart Jordan in NZ"
06-07-2011, 01:16 AM #
6 SAJ
Re: Shock Replacement
Here are pics of my M&S broken shock which I forgot to attach to my quick reply
