New-Revised RG & JS
Bill Lee/Virginia
I did not receive pages 13 thru 16 of Area 10 (Glass and Side Curtains) in my package of Revised RG & JS changes.
Did any of you miss those changes too? If so, what is the proper address to request those 4 pages?
Thanks.
Bill Lee/Virginia Peninsula
My revised section 10 ends at 10-12 also, but I scanned through the index a couple of times and don't see any pages beyond 10-12 referenced.....maybe 10-12 is the last page?
Area 10 is a complete, standalone new set of new pages. It ends at page 10-12. You are not missing anything.
I think it started with the instruction supplied with the RG/JS
Area 10 (Glass and Side Curtains) Insert with new area 10 (pages 10-1 thru 10-16)
Misprint in the instructions for inserting Revision 4
My instruction page was still in the recycle bin..
Sure enough, 10-16 was crossed out and 12 written in...
OK, that explains it then. My instruction sheet refers to pages 10–1 through 10–12. I must've obtained a later version of the instructions.
BTW, the back of my instruction sheet also says that there is a typo on the new 2016 version of page 1-11, and that I should replace it with the loose page 1-11 and 1-12 enclosed. (Typos will happen.)
If your Rev. 4 pack says page "1-11 Revised 2016" at the bottom and it does NOT have the word Carburetor in bold at the top left of the page, you do not have the corrected page. Let me know at tech@mafca.com and I will make arrangements to get the corrected page to you.
Ok....I fished the loose page out of the recycle bin. I don't know how it got there...
The one with carburetor in bold at the top and 1-11 revised 2016 at the bottom.
This is the correct page?
Thanks!
Yes! You need to put that in your binder. Toss the other page 1-11 away that just begins with text that says "and no attempt was made...".
You got it!
