Kube,
I assume you have a Zenith carb? They can be fussy if everything isn't right.
Yes, a Zenith.
Kube,
Looks like whats left of an idle jet.
Yes, standard equipment on the pickup trucks in 1940. My gosh you have good eyesight!
On the '40 passenger cars, it was a dealer available accessory.
Not a bad idea since clutch he's tend to do that after a long sleep. There are other was to break them loose but some ways can be a bit tricky.
Trans. is back in. Bit by bit
Ran the chassis around the yard today. What a blast!
Runs quite well, shifts smoothly.
Now? Can't get the starter to engage.
All connections are VERY clean and tight. 6.2v at starter.
I did disassemble the starter switch and cleaned it very well. Slight sign of arcing on contact that I'd carefully cleaned up.
Starter is not locked up.
Methinks bad switch and / or starter.
What else can it possibly be? Not much to the system in my opinion.
I remember back in the sixties when people traded in their cars once the ashtray was full!
Kube, you are persistent, ask and follow suggestions well, and are enjoying yourself to boot. This is a great example how, many minds working together can do good things! Best of luck on your project.
Ford's first starter switch for the model A was a rectangular shaped housing with an external pedal return coil spring with a shroud cover over the spring. These were very good switches but were not as simple as the late type switch used through the end of production. The actuator insulator inside the late switch likes to break and render the switch inop. Some folks pitch the litte cross shaped insulator and fabricate an insulator from nylon or delrin that is made to fit in there better. There should be a thread on here about this modification.
That sounds about right. It's not very big so yours may still be intact. The starter is a reliable enough unit but bushings & brushes are Iike any other as far as wear goes. If it rotates OK then it might have internal connection or heat related problems.
What sort of battery are you using?
