I am new to this forum so excuse my errors.
I just overhauled my 1930 Model A Motor, had inserts installed on the main, had block line bored to 125, crank turned to 30 over, connecting rods are babbits at 30 over, had the head and block cut (that's another story).
Started engine easy and have been using Snyder's break-in method, have run the motor for 3 hours, changed oil and new oil is valvoline 30 wt non detergent. Oh I used 10/30wt during break-in.
The problem I now have is it starts and idles really good, no noise, solid engine very quite. I have taken out on the road twice for about 1 1/2 miles each time and I hear a hissing noise, but when it idles you can't hear the noise. If I move the spark advance all the way up, you can hear the hissing noise and sometimes if the advance is about 3/4 way down, and rev engine a little, I hear the hissing noise.
Any ideas what might be the problem, or where I should look into??
I have a tilotsen carb; electric fuel pump (carver low volume 2 to 4 lbs), I have preasure regulator and a gauge set at 2 lbs, new auto lite plugs 64, temp gauge stays at 160, new water pump, new timing gears, new rebuilt oil pump, new distributor (modern type) new distributor gears, new clutch, perfectly timed, starter works very good, generator works very good and puts out 6.5 volts at idle, new radiator hoses, new fan belt new oil in trans and rear end 600 w from Berts.
I still need to fine tune the clutch, it's a little to low, have to go flush to floor board
One last thing, this is was my dads 1925 Model T and he installed the model a motor in the mid 60's and it ran untill now. I will post a picture of the runabout pickup as soon as I learn how to do pictures and when I get her running perfect
Sorry for such a long post. I live in Las Vegas, New Mexico
