OK, Barners, here's the mystery (at least to me) of the day.
A couple of weeks ago I returned from a 3,400+ mile trip to Albuquerque (was going to the MAFCA convention in Ruidoso, but that didn't quite work out...). During the trip my car was plagued with very poor power going uphill (especially at altitude), and overheating. Part of the overheating was the 100+ we had all trip, part was undoubtedly the questionable radiator, and part may be due to the lack of power causing me to push the car harder than it might otherwise have been with a strong engine. Lack of power was there even at moderate temperatures.
Before we left I did a complete tuneup - points gapped to 0.020", set timing, and changed plugs. I did switch from Motorcraft TT10 to Autolite 3076 since the TT10 are getting harder to find. I checked and regapped the points halfway through, they weren't out much (0.015").
Mid-trip I pulled the plugs and found #1 and 2 look pretty normal to me (right plug in the photo attached) but #3 and #4 were developing a distinct orange tinge to the electrode. Got home and the orange tinge is much more pronounced (left plug in the photo). In addition, #4 seems a bit wet upon initial startup. These were not present with the TT10 before I set out on the trip. And I don't recall noticing the lack of power before, but I haven't pushed the car like we did on the trip.
Other than low power, the car seems to start and run pretty well. Clear cap shows spark at all four distributor terminals, and switching out the distributor body doesn't make a difference. New head gasket within the last year. Compression is consistent at 80-90 psi. It's not using any appreciable amount of water other than what spews out when it overheats. Oil consumption is nominal for an old engine, quart every 500-750 miles.
I'm running stock Zenith carb. I purchased the car a couple of years ago and I don't know much about the engine except that it's 0.080" over with a large lip at the top. Some of the valves are way open (0.025" or higher) but there aren't adjustable lifters, so I'm presuming the cam lobes may be quite worn. It just might be, in spite of the good compression, that I have Old Tired Engine Syndrome.
I have a reconditioned engine with newly reground Jim Brierly "C" cam, adjustable lifters, valves ground and new rings that I'm going to install. And I'm going to switch back to TT10. Relatively new Bergs HD radiator going in with the replacement engine.
But the plug color of the 3076 and the lack of power have me confused. Anyone have any ideas of what else I could check? I don't want to do a parts cannon type of thing.
Thanks a million.
Thanks a million.
