Recommend replacing both Kingpins if either worn. Sold in sets ? I believe the replacements usually require reaming after insertion. Pending year, wheel alignment worth checking after installation but the camber angle is pretty much fixed by the forged axle. That angle is normally fixed unless the vehicle's axle has been damaged. If you can find a good quality front end shop and mechanic, just give them the alignment spec's and they can adjust their machine.
