New here, Carb? question/problem
Yikes! I'd tear it down and investigate... Remove the head and oil pan. Check oil for metal pieces when you drain it.
I'd start by pulling the engine, then take it apart. Sure sounds like a broken piston, so you'll also need to try to figure out why it happened. What would cause the piston to break.........too much spark advance, high speed, mechanical issue as a broken valve went through the piston top, etc.
If you are lucky, the block can be saved.
Sorry about your luck maybe it's not a you think hopefully a head gasket,just a thought older engines are already tired working them harder she might be saying to you take it easy ime old
