rons49
Well, after reading member threads on the quality of Brattons "Aluminum" reflector pans, I bought 'em and installed them. To be honest, my old ones were pretty good with just a few light dull blotches in the right side and near flawless on the left. The first thing that I observed was that compared to the new ALUMinized, the old ones were duller with a hint of a copper tone to the mirrored surface. Installation was as expected all went well, except that the parking light bulbs(both sides) tended to lose the ground as if the socket was too small in the pan sleeve. I needed to force in some aluminum foil to tighten the bulb sockets. Result of the 32 CP headlight was slightly better at idle, but when "reved" past the generator cut in speed, the lights down right Glowed. I found that there was no effect of turning the focusing screw. ODD! Never the less, they are better then the silver reflectors of a 20 year old replate. If you need new pans, IMO these are the way to go. Ron
