Usafexplorer
I know you will be very tempted to start the engine ,most folk do . You must remove the oilpan and pop out the dipper tray and clean out all the sludge and clean the pump gauze filter screen . Remove the timing chest cover and clean out the valve chest the main bearings are fed from 3 holes in the floor of the chest one each end and one in the middle .If the holes are blocked the crank bearings will fail .
John in West Drayton London England .
Thanks for the advice, the seller was determined to get it running and kept trying but I didn't push the issue for that very reason. I figured it had been sitting for years and the sludge was deep in the pan. It turns over so I'm optimistic everything will go well but won't know for sure until the pan is dropped.
