Dlistro1950
I'm looking for a flathead engine repair shop. The bottom end has a serious problem. Preferably looking for someone in the Hartford CT - Springfield area.
Dick
Southwick, Mass
Dick
Southwick, Mass
Dick
Southwick, Mass
Ronnie Roadster,
Where are you in CT?
Dick
Dick
Southwick, Mass
I agree with the above. When I was in high school, I was "rapping down" in second gear approaching a stop light. All of a sudden, I heard a load noise, and the engine started to knock. I shut it down, called my dad and towed the car (1951 Ford) home. I pulled the oil pan and found half of the center main in the bottom of the pan. Everything else looked good so the next day I went to the junkyard, picked up 3 or 4 center main caps, and then went to the auto parts store for some "Plasti-Gage". The first cap I tried yielded the proper clearances (with the original bearing shell which looked fine). After brazing up the hole in the pan, I put it back together and tentatively tried to start it. It started right up and ran fine. It was still running good (in another car) when I sold it five years later.
I wouldn't suggest doing what I did back then (when these were just throwaway cars), but you may no be in such dire straits as you may think.
With all those cracked blocks there should be plenty of main caps around.
Here's one to start you. https://www.youtube.com/watch?v=alqdj0OuFDYOk go to Utube type in "Leo Spinelli " then scroll to J&M Machine I think you should
watch all phases of machining process's they are not that far from you.....sam
I do not know how to put a link in here:
