Rancho Deluxe
Please check this conclusion….correct it if you can. It’s a mystery with a
shiny new rebuilt engine. Everything’s new, tight, fresh, and proper with authentic Model A parts. The distributor is authentic and in top notch condition. All great? No, the engine won’t run properly. It sounds like it’s timing is far too advanced. We’ve checked and rechecked this and set it up carefully and correctly. It won’t run anything close to normal unless the timing is set to the fully retarded position. Today we tried it with the distributor cam reset back (Clockwise) about as much as the width of the rotor blade. I’d guestimate that as 7 to 10 degrees retarded from the nominal normal position. That made the engine run much more normally and respond thru the range of timing lever settings. It was still sounding somehow odd but much better. Our reluctant conclusion as to the cause of this: The camshaft gear is probably meshed to the crankshaft gear incorrectly. One tooth off would account for the cam angle change. But how about the valve train timing advance? Would an engine run anywhere near normally that way? Are there any other possible explanations? Thanks fordbarners.
