Big hammer
New Engine QA and Paul Shinn's Concerns
As we work through this process with Paul Shinn and his videos/block measurements etc., I wanted to share details on the block manufacturing and verification process.
Factory Verification of the "New Engine" Cylinder Block
The factory in China we are using to manufacture the new Model A cylinder block has a dedicated inspection room to verify dimensions and ensure that the CNC machining programs produce parts within drawing tolerances.
The inspection room has its own HVAC system to maintain 72 degrees F and slightly higher air pressure than the rest of the factory. The higher air pressure keeps dust out when someone opens a door.
The inspection room has a computer-controlled Coordinate Measuring Machine (CMM), a large granite surface plate, and other precision tools used for inspection.
A cylinder block needing verification is placed in the inspection room and allowed to stabilize for 12 hours before any measurements are taken.
After stabilization, the cylinder block is placed on the surface plate, not restrained in any way, and measurements are taken using the CMM to verify compliance with the drawing dimensions.
For every "production run", the first cylinder block is inspected as described above.
Every cylinder block during a production run does not receive a full inspection with the CMM in the temperature-controlled room, but cylinder blocks are regularly pulled from the production line and measured as a part of the QA process.
Those cylinder blocks that don't receive a full CMM inspection still have their critical dimensions verified during the final inspection before receiving a serial number.
The attached picture was taken in the inspection room of the factory making the new cylinder blocks.
Paul Shinn's 2 New Engine Kits
A recap of the issue: Paul Shinn and his engine builder Willie stated they found dimensional problems with the 2 "New Engine Kits" in their possession and the first YouTube video published by Paul said that it will take $4800 to correct the problems if parts were taken from both "New Engine Kits" to make one running engine.
In the first video, Paul and Willie said the crankshaft and camshaft are not parallel by 0.007 inches, the crankshaft has a 0.005-inch runout, and the main bearing caps cannot be shifted sideways because they have dowel pins to locate them.
As many who monitor this forum know, Paul's video created a lot of backlash from those familiar with the "New Engine Kit", and it generated a lot of comments questioning his approach from those familiar with proper measurement techniques. Due to this backlash, Paul removed that video from his YouTube channel.
Paul created a second video – here is the link: ( https://www.youtube.com/watch?v=gU_G1AAkefQ ). In this video there was no further information regarding measurements, data, technique, etc. He stated he was committed to working with us (the manufacturer of the Burtz Block) by taking new measurements of the parts he believes are out of spec and posting his findings along with the original Ford engine drawing specifications. We agree with this approach; we asked that he identify each block and take specific measurements. To date, are still waiting to see his findings or response on the forums.
In response to Paul’s comments on the forum that he wanted to be rid of his block kits, I did offer a full refund to him via email sent on August 30th and asked for pick up information for the block kits. He replied that he wanted to work with us to make this outcome a “win-win” for the Model A community. We are still waiting for information regarding his measurement data and information related to the measurement technique.
It cannot be overstated we are very concerned about QA and if there is a problem, we need to know about it as soon as possible. Paul and Willie, please reply to this thread and post your measured dimensions, or let everyone know what your plans are for the 2 "New Engine Kits" in your possession.
Thank you for your update! Moving this #1 post so it easier
