New engine - intermittent backfiring - stuck valve?
SteveR.
I have a new engine with maybe 80 miles on it, built by a reputable manufacturer. It has started intermittent backfiring "fits" and corresponding power loss after it gets warm. I don't think it is the distributor or ignition, timing is correct, point gap is .020. Wondering if it is a stuck valve, is that common or likely for a new engine? What is the easiest way to check?
I checked between the upper and lower distributor plates, don't think there is a short there. Distributor worked fine with the prior engine. Low RPM & low load it runs fine, but when hot, it will intermittently run OK, then go into a fit of lost power & backfiring. Enrichening the GAV might help slightly, but the problem remains.
Might try some Marvel Mystery Oil as a first step. Squirt some directly in the carb and then add 4 oz. to a full tank of gas. Sticking valves are not unusual and MMO is often the cure.
Also consider it may be electrical, bad connection. Flakey ignition switch, terminals on the back side of the ignition switch intermittently shorting to the gas tank, ammeter nuts loose, points gap, etc.
If the motor was repainted sand distributor base and head off where the distributor sits on the head (major ignition grounding point for ignition). Another major ignition grounding point is through ignition cable - threads where the ignition cable screws into the distributor should be clean/paint free. And the stud/nut threads/ignition cable clamp for the ignition cable should be clean/paint free. Ive seen this on my A when its motor was rebuilt and a rebuilt distributor installed, both which were freshly repainted
Open up the GAV as you are driving and see if that stops the problem.
It could be starving for fuel, add MMO and do as the others have said.
After it gets warmed up and is acting up, pull the coil wire and hold it 1/4 in for a head nut, you should have a blue spark. If you have good spark ,look at fuel flow remove the carburetor drain plug to see good flow. On a fresh engine it is tight so MMO in the gas could help, 4oz per 10 gals or more.
Did you happen to get the radiator cap and gas cap switched? Run it without the gas cap on or when it starts to act up take the gas cap off and listen for it sucking in air when you do.
Contact the builder My wAG would a tappet came out of adjustment
Agreed- it's a new engine and the builder should guarantee his work. But since this is happening when the engine warms up, one possible reason is that, as jetmek said, valve clearance has come out of adjustment, getting too small. And as the valves heat and expand, they aren't seating fully. Running the engine like this can cause the valve(s) to burn.
It's lean. Find out why it's not getting enough fuel. Put a pan under the carb and pull the drain plug, then let it flow a couple minutes. I think you'll see it taper off to a trickle.
If an intake valve was not closing, it would puff flame into the intake manifold on every combustion stroke... EVERY combustion stroke. Not just a backfire once in a while. An exhaust valve that isn't closing would burn and you'd have a dead miss.
It's lean.
A little more information on this...
I haven't contacted the builder until I know for sure it is a valve...don't want to waste his time if it isn't his issue, and now I don't think it is.
Appears to be a fuel issue as Ak Sourdough suggested. The car runs great, always, under 40-45 MPH. No missing, good power, very smooth. Always fine in 1st & 2nd gear. When I get to 3rd gear, it will run fine even at full throttle until 40+ mph when I get deeper in the throttle. If I let off the gas for a few seconds then get back in it, it will be fine for a second or two until it gets starved of gas again. I disconnected the fuel line from the carb and get a steady, strong stream of fuel. Must be something in the carb. It is a Tillotson, should I just take it apart and clean it, or is there a specific place to check for trash?
Disconnecting the fuel line at the carburetor will not tell you if there is a wad of crud against the inlet side of the float needle seat or if the float stop is bent so the needle barely opens and doesn't allow enough fuel into the carb for sustained high speed travel.
Put the line back on and pull the plug out of the bottom of the carb, then try your flow test again. Or, just take the carb apart and find out what the problem is. You already know you have good flow to the carb so the problem is inside.
Pretty comprehensive description here.
https://www.youtube.com/watch?v=-wBALe0MUgs
Change out the condenser to see if that would make a difference. Nice Article in the most recent issue of the "RESTORER" about condenser.
Haven't read all the comments, sooo,,,,
Try loosening the fuel cap if it hasn't been mentioned or you haven't done it.
Fuel cap suggestions might be correct. A car on a recent tour had similar symptoms. Loosened the cap and the problem went away. Worth a check.
