Tod, Thanks for the info. Do you have a website with photos?
Brent,
Thanks for your comments.
I know who your engine builder was and I'm so happy that you no longer use him because of the 50% failure rate you were obligated to warranty.
I will not mention your rebuilder's name, but you endorsed him in an earlier FordBarn post.
Regarding your machine work, I'm happy that you are now rebuilding Model A engines in-house.
Are your machines accurate to 4 decimal places?
Can you explain to FordBarn members how you verify that a Model A cylinder block is rebuildable?
Steve Becker at Bert's finds that 1 out of 12 engines are economically rebuildable and can be guaranteed.
How do you verify that the pan rail has not been machined in the past?
How do you verify that the upper deck is parallel to the pan rail?
How do you verify that the cylinders will be perpendicular to the pan rail?
How do you remove rust deposits from the water jacket?
How do you verify water jacket wall thickness?
How do you verify that there are no fatigue cracks in any of the parts?
What is your remedy for worn camshaft bearings?
Do you add material to restore original surfaces or do you remove material?
Your reply with answers to the above questions is very important.
What is the cost of a rebuilt engine from you and what is your guarantee?
All of these questions are very important for you to answer because it will help people make decisions about whether to have you or others rebuild an original engine or buy a "New Engine".
If you don't reply, people will have a hard time making a decision.
Thanks in advance for your reply.
Thank you all for the information. I will be finding out more from Tod directly, I hope. I just put a supercharger onto my 1930 Tudor and would like to build an engine with 5 mains and better oiling to withstand the increased loads. This is not an immediate project, just an expectation that the original engine will not last forever.
Nothing against the Burtz engine, I think he has accomplished a fantastic feat in bringing the engine to production and everyone who has one seems to love it. I was hoping to find an engine that is not manufactured in China.
Oh goodness Terry, this seems like we are playing games on a 3rd grade level, ...and from my vantage point maybe should not be discussed in an open format on someone else's platform. With that said, I will honor your request and answer some of your questions in generalities which might potentially assist others in making the right decision for themselves.
Yes we do offer a warranty (-which I feel is one of the best in the industry). Yes, I own quality engine machining equipment capable of holding tolerances into the tenths. Additionally we are likely adding a CNC machining center to our equipment line which potentially could raise our level of craftsmanship past the amount of decimal places you asked about. We also use both a wet & dry magnetic particle inspection tester, a sonic tester, and thermo-pressure testing equipment to check for some of your concerns listed above. And yes, we do have other specialized equipment that we oftentimes use to correct and/or repair wear/damage to each piece of the customer's project.
FWIW, unlike some other shops (-and maybe that applies to you too) we have our own equipment to use inside of our own facility for the sole purpose so we do not need to rely on the craftsmanship (i.e.: machine work) of an outside source which at times can be found to be inferior and/or outside of acceptable specifications which cause Q/C issues at a later date. Many of us can attest to having first-hand experiences with this type work which left a bad taste in our mouths.
One other point that I feel should be considered about my shop is that we are 'Restorers' and not just parts exchangers. Not everyone that we assist has the desire, -nor the option to replace their engine block. We want to be problem solvers to those who may not feel your product is a good solution for them. Therefore we are just trying to be full-service shop offering a value to a customer with their engine rebuilding needs. Nothing in my post should be construed as detrimental or derogatory to you and/or your products(s).
Making the larger main bearing caps is yes expensive time consuming. The real work is machining the block to match. Solution is grinding the "B" crank main bearings to "A" crank size and go from there. I have one in my latest engine build and is working fine.
Cracks, the cylinder bores, and or the crank journals too small....these are the real things that jump up and bite a person on rebuilds.
Synchro909, the "B" crank I have had already been machined quite a bit. So going to Model A size was no worry. I cut the mains down to 1.625. The crank still has the thicker casting and as cast counterweights, so I think I'm still ahead of the game with it. The "B" crank is 2 inch main and rods stock. I have another "B" crank stock size waiting for a "B" engine build. Although I do have a Burtz engine that will be next. Can you still get a Burlington crank? I know you can get a Scat crank but about $2k I think.
Machining the block like that and making the caps would be very costly unless you could do it yourself. Also trying to find a machinist wanting to do it.
Regards, Brian
Gene, I know what you mean about the China stuff. The problem is that we (USA) make almost nothing any more. It jumped up and bit us hard when the pandemic hit. We can not turn the ship on a dime, and it will take time to undo all of that.
Every time I need a new pair of tennis shoes it kills me to shell out that money for something made in Vietnam. Vietnam if all places. They tortured our POWs for fun. Let me say that again, just for fun. They tortured a few of them (along with help from the Cubans, arranged by the Russians) to death. No I have not forgotten. Any time I can buy something made in the USA I do, even if it costs a little more.
Gene (the other Gene LOL)
Apparently, the work Tod does is spoken for far in advance of the manufacturing. I am happy for him but wish I could get one of his blocks.
Brent, Tod mentioned a desire for more capacity if your machine shop has capacity, maybe you could help him expand?
