New Engine and Flywheel Housing
Terry Burtz Calif
At the Turlock Swap Meet on January 25 and 26, we will sell "New Engine" parts at "Event" pricing.
We have a preproduction "New Flywheel Housing" for evaluation and approval. Please stop by our space in the building with the snack bar to buy parts, and see and discuss our new flywheel housing, which looks original but is 12 times stronger.
Original Model A flywheel housings crack at the 2 lower attachment bolts because all front axle loads transmitted through the wishbone become bending loads on the flywheel housing.
Ford knew about the problem and during the 4 years that Model A Fords were manufactured, the flywheel housing design was changed 8 times. The last change on October 26, 1931, added external ribs to areas that are lightly loaded and don't crack.
Our new flywheel housing is an improvement on the 7th revision, it is about 12x stronger where they crack and come with an O-ring groove and O-ring to seal the back of the camshaft.
Our new flywheel housing has several internal changes that are hidden. The thickness at the attachment bolts has been increased from .500 inch to .875 inch which is 3 times stronger, the width of the material at the lower attachment bolts is twice as wide, and the new material is about 3 times stronger than grey iron. If you do the arithmetic, the strength at the 2 lower attachment bolts is 3 x 2 x 3 = 18 times stronger than the original. Being conservative, I'm comfortable saying that the new flywheel is 12 times stronger than the original.
For blue point judging, the exterior appearance of our new flywheel housing is correct for all production before November 1931.
Contact John Lampl at www.burtzblock.com for pricing and delivery details.
Do you have any photos or drawings showing where the ribs were added on the final design? The JS doesn't say anything about this change, but I assume it's visible if you're looking for it.
Thanks for your question.
I do not have a picture.
The ribs are visible because they are external and fore and aft at each bolt hole where the bell housing bolts attach to the flywheel housing,
The latest design was the over-the-counter part after Model A production ended.
Perhaps someone on the forum can provide a picture.
You can order drawing A-6395, EI20912, dated 1931-10-26 from the Ford Archives to see the ribs.
The Judging Standards are evolving and don't mention this change. When I asked the question regarding the diameter of the cotter pin at the bottom of the flywheel housing, all respondents stated 7/32 inches. The Judging Standards state 3/16 inches.
I saw the bell housing today, it is really beefy, shouldn't break this one......
Keep the goodies coming Terry....
That’s very cool. Since the flywheel housing has an O ring, do you still install the gasket. And if not, do you still install the shims. Thanks
I also saw it and chatted about it with Terry. I was very impressed. Excellent work, Terry. Let us know when it's available for ordering.
Y-B: I asked Terry this very question. He told me that he did not think the gasket was necessary, and so the shims would not be either. That assumes that the O-ring makes up with perfect fit. I think I'd dry fit and check those top eyes with a feeler gauge before I decided to leave the shims out. (That's how I do it anyhow, I don't just add shims, I measure the gap and shim to match.)
