supergnat
I needed to replace the king pins on my 28 leatherback and ordered a spindle rebuild kit. After cleaning the spindles and removing the old bushings I gave the new bushings, new king pins, and my original spindles to a machine shop to install and hone the bushings and match the king pins to the spindles. When I attempted to install the spindle and king pins on my 28 Leatherback yesterday I encountered a problem. The opening at the top of each of the king pins was too small to accommodate the brake shaft assembly which slips into the large round opening at the top of the king pin. Both king pins had the same problem. Both of my brake shaft assemblies easily slipped into the top of the old king pins. Since I had already paid to have my new king pins matched to the new spindle bushings I enlarged the openings at the top of the king pins to accommodate the brake shaft assemblies using my Dremmel tool. The openings on the problem king pins appear to be about .010 undersized.
I just sent an email to the supplier suggesting that they check and purge their stock. If anyone is about to use a newly purchased kit be sure to check the fit of the brake shaft assemble first.
Supergnat
Supergnat
