Hello Spert,
I also bought one from a supplier I had trusted since 1971. Surprise! THe flywheel balance was still dead on, but the NEW pressure plate was so far out that my longer-time-trusted local competition engine builder told me he would not be able to do ANYTHING to balance it, and offered an opinion that it was "cheap C... s...". Sympathetically, he blanchard ground a used plate, helped select and test a set of used original springs, and when I assembled the whole pressure plate cover assembly, he checked that the assembled pressure was within the Service Bulletins' specs. It balanced dead nuts and went on the flywheel, still good. (Thanks again for caring,"Joe').
I called the present owner, and heir, of the trusted supplier. " That's impossible, he said . My people and I would NEVER send out something like that! You must have tampered with it!" He offered to let me pay to ship it back, and would look at it. No consideration of a refund, but I could buy another one, and pay shipping. Three shipping trips out and back was pretty close in cost to the listed price of another one of the same CCS, so I kept it.
I took it apart, and the half the springs, adjacent on one side of the assembly, were one color. The rest,on the other side, were a different color, and heavier. They each tested at 60 to 75 lbs at 9/16" compressed on trusted 'Joe's' professional spring tester, like used valve springs. For amusement I reassembled the whole, the same way, and put it on an engine on a stand with a trans and used a load cell to find a foot pedal pressure of 110 lbs. Ford claims "you would only need 35 lbs. to release the clutch" (foundI in service bulletins ,manuals, and period advertising lit.
So much for that supplier ( someone known and loved by all, so far). What would all that do to my rebuilt engine's thrust bearings?
Looking for the wisdom to know the difference,
ARDVAARK
PS: "Of course those trans roller bearings are US made, perfectly good quality."
And again, "The copper clad manifold gaskets aren't available right now. The ones
we sell will be all you need".
