TinCup
I have been helping install new cast iron drums from Snyders. This work is being done on an absolutely fabulous 1931 Slant Window Sedan. We are having issues with the front drums.
First thing I did was to back the brakes off completely and disconnect the front brake rods. Now when I install the drum and tighten the nut the wheel locks up as if the brakes are too tight. I first thought that the drum was going to far up the spindle and was rubbing against the backing plate but there is plenty of clearance. I completely removed the shoes and the hub spins perfectly on the spindle. Put the shoes back on and it locks up.
Where the shoes ride in the drum could it not be deep enough? Or could if be that the shoes which were arced to the old steel drums too tight?
Toss this dog a bone if you have an idea!
