Archie Cheda
A list of good ideas . . .
Bob,
I want to thank you for taking the time to type out such a comprehensive list. I also hope neither you nor anyone else will be offended by my choices, which are tailored to my personal compromise between an absolutely 100% original Model A and a highly modified version. In other times in my life, some of these selections would have been different. Even before I purchased this coupe, I decided that I did not want to depart very much from stock, but that I would make improvements that would enhance my enjoyment of the Model A experience.
For me this experience includes things like:
o Shifting a non-sycro trans (I enjoy double-clutching -- learned how to shift gears my Dad's '51 F1 which had a "Brownie").
o Being able to adjust the spark advance and mixture at will while driving.
o Being able to start the engine with a crank -- did that for a whole year on my Grandfather's '37 Dodge pickup while I procrastinated buying a new starter switch.
o Having mechanical brakes that need me to adjust them. (It is nice to be needed . . .)
With the above mind-set, and keyed to the original list, here is what I am currently thinking:
I need to do more research and am still on "input mode". My personal inclinations and many posts I have read promote the general idea of "if it isn't broke, don't fix it". Applied to the Model A valve train that would mean sticking with the original split guides and valve/keeper design but I see poorer exhaust valve cooling and valve location with the old system, so I am likely to come down on the side of modern guides, keepers, & valves. Regarding seats, I already seem to have inserts, probably on the exhaust only, so I will be installing at least one oversized seat, probably for all four exhausts. If I still have integral seats on the intakes, I will probably leave it this way. I have done valve jobs on two Ford FE engines that each had three exhaust valves sunk over 1/8" into the heads, but have not seen a problem with intakes, and these were hard-working (towing) engines.
This is still open in my mind. I have decided to use modern (narrow) rings, but may stick with original-style pistons (but with narrow ring grooves). I view the engine I am building as the mildest of non-stock engines. The mild cam and compression ratio are the equivalent of where stock engines were later on in the thirties.
I am keeping an open mind until I can determine what the quality of the babbitt job on my engine is.
I will be going for a low-rpm engine, so will probably stay with the traditional oil system design, which seems to be pretty elegant to me.
I will probably stick with a standard cam bearing size or go oversize if I find wear in the block. I am fine with running the cam in the block as I will not be neglecting maintenance.
Again, I will be sticking with traditional. I weighed my flywheel and it is original weight. I had a 312 Y-block 45 years ago with a Scheifer aluminum clutch and flywheel, so I have enjoyed the thrill of a light flywheel. At my age, the heavy flywheel is more appropriate.
Already purchased, along with a new steel crank gear. I will editorialize my preference for replacing both gears together. Old crank gears can be worn undersize by abrasive material lodged in the cam gear, or may be rough enough from rust to "eat" a new aluminum gear. In the world outside model A's every gearset I have ever purchased was in one box as a matched set. I will be checking the crank to cam bore distance and will correct by align boring & using an oversize cam if necessary.
Here I am "old-school" and believe that an original 6-volt system will work fine if it is 100% in proper order. (I have owned two 6-volt autos and two six volt tractors.) I will be adding a bonding strap between the engine & frame. (Note: I will not be driving at night and will have absolutely no electrical accessories.)
Here I will also be sticking with the traditional system. My distributor has been converted to "new-style" points, but I will probably eventually convert back to traditional.
My plans include a Snyder 5.5:1 head.
I think I will be OK without a thermostat in my local climate, but this is an easy thing to add at any time.
I did a quick flow-test and my radiator seems to flow well, so I will see how well the engine cools with an open system.
I will probably stick with the pump I have as it can easily be upgraded when the need arises.
I will probably stick with tradition on my low-rpm engine.
I have been "cogitating" on this for a while. I may machine my own adaptor and may stick with a by-pass type filter as I will not be driving on unpaved roads.
After reading a lot of opinions, I am inclined to stick with the traditional system, but will be very careful with details about the oil return pipe and keeping a free crankcase breather cap (more below). I am considering (very carefully) doing a positive crankcase ventilation (PCV) system, but it will be very carefully designed and integrated, not just a modern valve slapped onto the engine.
I am not clear on this. I do plan on not using my OLD original, but was planning on sticking with a two-bladed fan. All my experience and education is that when driving over 25 mph, the road speed moves enough air to make any fan redundant. I do not expect to be caught in traffic jams, or be towing, or be climbing many steep grades. (I have a still-living cousin that is 95 years old and still has a 1931 Coupe -- the last of his four Model A's. He tells me that the Cuesta Grade is not a problem for a good-running Model A.)
Thanks -- I will do this, even though it will require me to do some re-painting of my pan. I had not yet run across this advice and appreciate it.
This is part of the attention I will be paying to making certain my traditional rear "seal" is working properly. I also feel that a very mild PCV system will help. Anyone have opinions about the one-piece FRONT seals vs. traditional two-piece rope seals?
FINALLY, I am open to logical discussion of these sorts of things and would welcome more tips as this project progresses.
Archie
Bob,
Bob Bidonde said:a) Modern straight shaft valves, one-piece press-fit guides and press-fit valve seats;
Bob Bidonde said:b) Modern pistons and rings from small block Chevy & Ford V8s;
Bob Bidonde said:c) Modern insert type main and connecting rod bearings;
Bob Bidonde said:d) Pressurization of the oil to the main bearings;
Bob Bidonde said:e) Press-fit camshaft bearings;
Bob Bidonde said:f) Lightened flywheel and V8 clutch;
Bob Bidonde said:g) Aluminum timing gear;
Bob Bidonde said:h) Conversion to 12-volt electrical system & ignition primary;
Bob Bidonde said:i) Pertonrix 40611 hi-voltage ignition coil;
Bob Bidonde said:j) 5.5:1 or 6:1 compression cylinder head;
Bob Bidonde said:k) 160 or 180 degree stainless steel thermostats;
Bob Bidonde said:l) Pressurized cooling system;
Bob Bidonde said:m) Water pump with press-fit front bearing & double sealed rear bushing;
Bob Bidonde said:n) Modern connecting rod cap nuts without cotter pins;
Bob Bidonde said:o) Oil filter installation. There are several to choose from;
Bob Bidonde said:p) Modern rear main bearing oil seal, but this requires machining the crankshaft;
Bob Bidonde said:q) Modern cooling fans. DO NOT USE AN Original!
Bob Bidonde said:Be sure to solder and or braze the oil drain plug thread insert into the oil pan so it does not spin or weep oil.
Bob Bidonde said:Make sure the oil return pipe in the rear main bearing is not screwed in so deep it impedes the flow of oil.
Archie
