Dan McEachern
Terry-"duration with valves seated" is not very informative without knowing the valve lash. Also, it would be usefull to know the duration at .050 as it is a big help in comparing to other cams. Thanks!
Not applicable for a Model A but there is such a thing as a variable timing camshaft. It uses a roller follower and has a different profile along the length of each cam. The camshaft is moved in and out to change which part of the profile is active at each engine rpm. I think that race cars have solenoid activated valves so that the timing can be changed using an engine management computer. I could be wrong.
