Another thought that doesn't have anything to do with this project technically but what would be a possible way to market and service this block?
Tod do you have plans afoot on this subject? Will you be assigning specific vendors or do you have the ability to do that inhouse?
From past experience having knowledgeable key people to handle any issues that might arise at with the consumers can really make a difference.
It might even be something that FoMoCo themselves would like to add to their performance parts department. In fact the having a Ford part number might even help the psychology of those desirous of using genuine Ford parts in their cars. (Even though a million guys seem to have no problem putting Gm power in their Fords) lol
I need to be able to deal through builders. They can supply finished blocks to customer specs. One thing I learned early on in the FE projects was that I need to be able to supply a basic machined block that can be finished to stock and beyond. There are too many ways to finish a block for me to cater to individuals.
I doubt I will be doing anything with Ford.
Tod
I typed up some stuff yesterday but yet again the site timed out and it all went away. I will do it again soon. Tod
I think you have the right idea - as there are a zillion ways to build a flathead Ford. There are many guys that will want a 'new' and reliable engine that is close to stock specs (bore, stroke, etc) - there are others (like me), that would only buy a block like this if it can extend the performance capabilities beyond what is possible with a stock block. The primary area where I'd want the ability to 'finish' the block is in bore size and cam bearing size.
The other area where I think you'll need to really think about and then make some firm decisions is the whole valve train "package" that comes with the block --> you should include a much better port design (intake and exhaust) - such that everybody benefits from better flow. Some 'performance hounds' like me will take the "as cast" port designs and port/blend them even further - for larger cubic inches and higher performance. With this said, I would probably think about what initial valve sizes you include "out of the box" -- like 1.72" intake and 1.6" exhaust. I would not want to have to bore out and put valve seats into every block - that gets expensive for every builder. So - you might as well go with a larger hardened valve seat from the get-go.
With the above said, I'd still like the option of buying a block without any valve seats at all (would think at a cheaper price) - as if I'm building an OHV conversion (like an Ardun), it makes no sense to pay for them or for you to invest the machine work/parts/time . . . only to not use them.
Another peak performance idea just came to mind: Would be interesting to explore the potential to move the intake/exhaust bowl/guide locations maybe just a bit further apart. I've not done any measuring, but I will look into it (to see how much room is available), impact on heads/studs, impact on cam lobes (if it can be done), etc.. I would LOVE to have a larger intake valve (if the port could support the flow) - beyond 1.72" with a hard seat - and the only way for this to work is to move the valves a bit further apart. Anyway - just pondering the 'ultimate' design a bit further in my mind . . . will look at my CAD models when I get home next week. Something fun for me to look at . . . LOL!
Now, I think this id getting out of hand. Moving the valves, means mpving the lifters, which means replacing the CAM. I try to think out of the box here and belive that you can't make a silk purse out of a sow's ear..
Thicken the deck
re in-force the mains.
Remove the water jackets around the intake ports.
Raise the roof of the intake port.
Now you have a block that fit; all comers, You'll even be able to bolt on a 21 stud head. Something like this would please most people.
I really believe this is our only hope.
PS I have a block that I've been cytting up and I could send you some pieces.
A horse of a different color...
https://www.kaiserwillys.com/new-4-...ck-fits-41-53-jeep-willys-with-4-134-l-engine
Go man go!
I'm not moving valves. I have too much work in the center exhaust port alone to scrap that idea. The best I could do would be to provide a casting that is not machined at all in the valve areas and let the customer machine them where he wants. OR, I could do one (or however many) special order which would cost a ton to program.
Ron has pretty much hit what I'm aiming at. I am working on the ports a little as I finish the external details. Thickening the deck alone, and making blind deck bolt bosses is challenge enough with the limitations of the block parameters. Let me get something that is better and then I can always make reasonable changes after that prototyping is complete. If I can get 5 or 10 of these spoken for then we can think about other things if need be.
I will post more details asap. Daily work will be getting back in the way now that the holiday is over.
Tod
That Jeep engine is interesting in the positioning of the intake and exhaust ports.
Notice that the intake port centerline is lower than the exhaust?
Well I think that was done to prioritize intake port efficiency. This gives the intake port added room to more gently rise up to the back of the valve head.
I imagine that a Flathead Ford's intake port could be designed such that it curves up to the intake valve more gradually reducing the abrupt turn the charge must make in the valve pocket area.
I believe that if done carefully that the original intake port entrance could be maintained to line up with the stock intake manifold runners.
This would be a huge jump in volumetric efficiency in my humble opinion.
