I'll see what I can do about the oiling, but if I make a galley through the lifter bores it only helps if the lifters used are able to allow oil flow all the way through. I don't think stock lifters allow that, do they? I may have to make a galley so that when the lifter bores are cut it cuts into the galley some, allowing oil to pass along the side of the lifter. Kind of like the Clevelands were.
Not sure yet how I will do all three mains. The cam journals can be oiled from the top. A boss above each journal is drilled down through a top/center galley and then plugged with a 1/8 NPT plug.
Tod
